Thanks. I tried that once, without the rag as a seal. I will try again.
I might try reversing the situation by doing the same attempt with a
manual bilge pump....kind of a plunger effect.
I have a small stream, about the size of a straw coming through without much pressure.
Should'nt the hose be flowing a full hose sized stream? Therefore, the intake water flow would
be my problem, not my pump? Correct?
Thanks.
Bowie
