Re: Untrasonic Speed Transducer
Ted
it was the instruments setup I found difficult. its not a linear calibration, at least on my ST50's.
my trasncducer is slightly to starboard in front of the keel. I thinks that's done to reduce turbulence at the transducer from the keel. I don't race so I can't attest to the difference in speed port/starboard tack. I'm on MA Bay so the currents are always something to contend with. I'm on a mooring and the transducer will pick up 0.1-0.2 knots of current as it ebbs and flows. course it will pick up higher readings also. so depending on currents, I'm quite sure that any differences in boat speed on different tacks would be because of current conditions.
also I had a conversation with a tech at Airmar and the transducer reads the SOW relatively close to the hull, so again doubt moving it will do you much good. I'd think it would be far more important to insure the orientation of the transducer is correct to the boat. I think you'd be very happy with the transducer.
