The bonds that we are most concened with are cohesive and adhesive. There are several other types of bonds.
Cohesion happens when a material sticks to itself. Epoxy will stick to epoxy while uncured and when cured willl form a solid mass that shows no joints.
Oil and water are not cohesive.
Adhesion happens when epoxy sticks to another material such as wood or existing fiberglass.
A mechanical bond happens when a nail, screw, or bolt is used to join to items. The hinge to the door for example. A dovetail joint is also a mechanical bond.
A fusion bond happens when two like materials are joined by partially melting and mixing the joint area. This is also called welding.
A metallurgical bond happens when two metals are joined by soldering with a third metal of lower melting temperature than either of the first two. Example using silver solder to join stainless steel to copper.
