two newbie questions ...
eliems
Apr 26, 2011
102
Hunter H28 Port Moody
regarding specs on my H28:
First does mast height (47'6") mean height above the water?
Does displacement mean total weight of the vessel or potential displacement when fully loaded?
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
It generally is measured from the DWL (Design water line).. so if your mast height is 47'6", that is the minimum vertical clearance your craft needs to clear overhead objects.
It should be the 'dry' weight without any people, gear or provisions.
Cheers,
Brad
