Dalliance has always had what I take to be two cutlass bearings; one at the Y-strut and one in the stern tube. In all the work underway this spring - pulling the engine and transmission, replacing the shaft log hose, etc. - the stern tube cutlass bearing has somehow fallen out. Nowhere to be found. I even pulled off the new shaft log hose to make sure it had not gone that direction instead of out of the boat. Gone.
I'm told it's not necessary, but then why was it there? Was this original to the Cherubini H30 or a modification? Do I need it?
Photo taken without bearing. Shaft a little off center right now, but it's not reconnected to engine yet.
