Two axle or one for trailering?
E
Eric
The Macgregor 26X I just bought didn''t come with a trailer. I'm leaning towards a dual axle trailer but was wondering if there were any drawbacks over a single axle? I'll be using it a lot. Eric
Tom
2 axle tracks better, but...
2 axle tracks better, doesn't sway as much. 2 Axle trailer will be more expensive and requires 4 tires/hubs to maintain, etc. Fair winds and roads, Tom
K
Kevin
Two
I have a 26x and would rate the trailer as my greatest complaint. A tandem axle trailer would be a beautiful thing. Greater weight capacity--the stock trailer is at the edge of its limits, tire redundancy in case of blow out, better tracking & stability and easier backing. K
H
hp
depends on weight
I would check with your dot and see what your allowed on a single axle.you will be responsible if anything breaks,and we know how hungry lawyers are.i would go with two axels if for nothing else safety.you say you will be using it a lot,if you have a flat on a double axel the other tire will allow you to get to a lot safer place to change the tire.hope this helps,good luck.
Mark
2axles
I'd go with 2 axles. I'm considering changing my 22oday trailer to them. There's a little bit of dragging, sometimes, in sharp corners, the farther apart the more there will be(theorectally). Pluses outweigh minuses.
