Twisted batten
JHS
Jun 26, 2004
24
Hunter 29.5 Pultneyville, NY
I have approx. 10' batten that has developed approx a 180 degree twist. Any suggestions on straightening same. Will clamps work? or is Heat needed? or is it time to get a new one? Joan
Nov 6, 2006
10,257
You could try heat to the area of the twist while clamping it straight, but ya probably better off just getting a new one. Take the old to a sailmaker and ask what caused it to do that..
Johnb
Hunter 37-cutter Richmond CA
If it had been under the sail cover on the mast for a long time I would guess that the sail slipped on the boom and put a twist in that batten.
Oct 29, 2005
2,366
Sometime you want some twist in the sail for that little bit more speed. Now you have it ;)
