Leech to top batten angle
Neil,You look at the angle of your boom compared to the angle of the top batten. You make them the same as a rough guide to initial twist set. You really don't sight up the leach as it falls off on a curve from the boom and then comes back in as you go up the sail. The tell tale at the top batten is a better indicator, however the top batten parallel to the boom is a good starting point.
