Don Guillette
Let's talk about TWIST. First of all, what is it? It is the leeward sag of the leech of the sail. It is easy to spot on the water as 75% of the sailors sail with it all the time. To see it, stand in your cockpit and view the leech of the sail from top to bottom. If your sailing close hauled, the top half of the sail will look as if it is sailing on a beam reach and the bottom portion will appear to be sailing close hauled. Why do we have to deal with TWIST in the first place? The answer is because there is more wind at the top of the sail than at the bottom. The wind blows 60% greater at the top of a 40' mast than at deck level and the reason is FRICTION. When wind blows across the surface of the water it slows down, so stronger winds aloft necessitates some twist in the sail and sail makers design some twist into their sails, but to get 100% efficiency from your mainsail, it has to be as even as possible from top to bottom. In other words, you can't allow the top of the sail to be on a beam reach and the bottom close hauled. To compensate for this problem, the top of the sail needs to be eased as if on a close reach and the bottom has to be trimmed hard as if on a beat. Without sail trim controls, you could not make the twist adjustment. As a note, a lot of sailors think there is a CRUISING way and a RACING way to sail a sailboat. Actually, there is zero difference between the two and only a RIGHT way and a WRONG way to sail a sailboat. Think of TWIST as "power off" (brake) and "power on" (accelerator). The MORE leeward sag you have in your mainsail the LESS power you are generating because air is spilling out of the top of the sail. The LESS leeward sag or the straighter the leech, the MORE power you are developing because you are containing the wind in the top of the sail and generating power. You may have to read this paragraph a few times to understand what I'm trying to say. Fine tuning TWIST is the most important sail trim adjustment you can make. The sail trim controls used to adjust twist in the mainsail are the MAINSHEET and the BOOM VANG. INCREASING tension on these controls REMOVES twist and DECREASING tension ADDS twist. The next time your out sailing, experiment with these controls and see what happens. Follow these easy steps: Step 1 Sail close hauled Step 2 Position traveler so boom is near center Step 3 Trim mainsheet until top batten is parallel to boom Top batten can point slightly to weather Top telltail should stream - if it curls, ease sheet Step 4 Ease traveler down Top breaks first - trim sheet in (too much twist) Bottom breaks first - ease sheet out ( not enough twist) Step 5 Twist is now set Step 6 Pull traveler up to obtain 3 to 5 degrees weather helm on rudder. Any questions?
