Ranger Paul
I have a Hunter 216. I want to be able to control the main sail twist easily when close hauled with the main sheet trimmed tightly, that is, with a lot of tension on the main sheet. Specifically I want to hold up the boom with something adjustable. Obviously if I used something adjustable and wanted to increase twist, I would have to ease the main sheet, make the adjustment, then trim the sheet.There seems to be three choices, the topping lift, a boom kicker or a rigid vang. Topping lift - Using the topping lift for this purpose doesn't seem like a good idea to me for a couple reasons, 1) it could be nasty if it broke under the load and 2) I have a fractional rig and I'm not fond of the load I would put on the upper section of the mast above the top shroud/forestay tangs. I admit to being green enough that I don't know if topping lifts are used for this purpose. Further, the topping lift has to be to the weather side and it would be difficult to switch from one side to another.Boom kicker - I suspect these do not have enough "kick" to overcome the main sheet tension when close hauled.Rigid vang - Been looking at the Garhauer (as it is the only one I can afford!) Will this have enough "up" force with the in-build springs to induce the twist I want? This could be a nice choice for me as the 8:1 vang that came with my boat is inadequate.Any advice would be greatly appreciated.Happy Sailing
