I am trying to iron out some things on my Capri 25, and I know that the Capri 22 is very similar in the foredeck configuration for the symmetrical kite... so I would like to pick your collective brains on how my configuration is setup.
First I have read that, having a separate sheet and guy per side on a 25 footer is likely overkill, so I've worked under the assumption that was unnecessary.
Second, with 1 line acting as sheet (for the leeward side) and 1 as guy (to the pole on windward side), it forces the roles to be reversed upon jibe....
With those two things in mind I want to describe what I did, and why I know it's wrong, but am looking to "fix" it.
I've run my sheet/guy from forward down to fixed ratchet blocks on the rail at the widest part of the boat (just behind the bulkhead for the dog house)... then to turning blocks all the way astern... I know instead of the ratchet blocks, I should likely use snatch blocks on the sheet/guy, and down to a block on the rail (could be the ratchet block that'd be fine) to TWING the line when it's acting as a guy... and manage it when it's acting as a sheet (to open or close the leech)...
Am I on TRACK so far?
I am using THIS as my guide to rigging:
What above refers to is D and E in the image. My wrong configuration has D and E being fixed to my rail as a single block, and the guy run through it... bad juju, it closes the spinnaker down on the sheet side (it works, but it closes it). What I proposed to the foredeck was a way to change out what I am using to a kind of twing, but I think I need F a cleat (the ratchet blocks might help me delay that now, but one of the genoa trimmers is trimming doing trim for the spinnaker while we run, so he's pretty busy, the other genoa trimmer could be in charge of adjusting the twings I guess and we could forego the cleats for now).
Ok assuming you understand my question on that, I'll also note that my foreguy (pole downhaul), IS NOT directly under the bridle on the spinnaker pole like B in that picture. It's instead at the base of the mast... it seems that it's easier to adjust sheeting that way when the pole can rotate around the mast. Not sure if that factors into anything but I thought I'd mention it. I cant' go back to having the foreguy downhaul dead center of foredeck either as I broke the block that was originally there.
So I guess what I am saying is, do you any of you have any pictures/tips or rigging ideas that might be better than what I am doing? I do better with visuals as I am a slow learner.
Oh and we've tried launching from the pulpit and also from the companionway... I personally prefer from the companionway, but the foredeck wants to do pulpit (argument is it's easier)... Thoughts?
