So I buy a 2007 Hunter 45 CC and find out the OEM 23" Solé TV is not capable of receiving digital TV signals. The previous owner installed a digital TV antenna at the mast head but was never able to use that function. It plays DVDs and can display the chart plotter only. So bought a new Westinghouse 32" TV for $99 at Best Buy. I then removed the Solé off the wall bracket and discovered it uses an S-Video cable..UGH (that shows its age!) and the red and white audio RCA cables. Problem is the TV I bought doesn't have an S-Video connection (that shows its age also), but does have the VGA input and several HDMI inputs. So then I go on Amazon and buy an S-Video to HDMI adapter. Next problem was the bracket that mounted on the old TV was smaller than what would work on the new TV. So I fabricate a wooden mount and attach the old mount to it. Next problem was the power plug coming to the old Solé TV uses a plug similar to a power plug into a PC laptop, and the new TV uses a regular fixed two prong plug, so I go back on Amazon and get an adapter for that. I also bought a 1' VGA extension cord and already had a short coaxial cable to make sure it the cables will reach the new TV inputs (the cables in the boat are fixed and there no easy way to lenghening them). I'm waiting for the one VGA extension cord and will finish the assembly and take it down to the boat and give it a whirl. Any bets whether it all works???
