TV Reception
8
Catalina 30' Seabrook, Texas
I am looking to hook up a tv in my Catalina 30. The set is digital and all I want to receive are local stations. I was just about to purchase a Shakespear 24" omni directional antenna when I looked at previous post for tv antennas and one writer said he used his VHF antenna for his television. He said all you need is a splitter that uses the VHF cable from the back of your radio. Question, the radio and television use different cables. I'm not familiar with a two into one spliter that splits the two different cable types. Is anyone familiar with this? Does it work or was the writer pulling someones leg? Thanks for any imput.
Apr 9, 2010
8
Thanks to both of you but I don't believe either will work. The antenna form the mast to my VHF radio uses a RG-58 cable plug and the TV uses a RG-59 cable plug.
Joe
Jun 1, 2004
8,351
I use a simple table top digital antenna.... purchased at Best Buy for about 25 bucks.
It requires a 110 power source... as do most digital antennae. There is a marine product that can be mounted on the mast for substantially more cost.
If I were you, I'd try the cheapo unit first...
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Neither of the above suggested devices will work.
The first is a wideband 75 ohm to 2 x 300 ohm splitter, and VHF antenna coax is 50 ohms, so there would be a mismatch, your VHF reception would suffer, and it would possibly blow the transmitter... and the second, which IS meant to go onto a 50 ohm VHF line, is actually a filter which only passes < 120 MHz or so to an AM/FM radio, whereas DTV channels extend to UHF frequencies.
There are some small active DTV antennas (as per that other thread), I would just get one of those, 30' of coax and hoist it with a halyard when you're in port.
1,096
CS 30 Toronto
Sorry to disappoint but it is actually simpler and cheaper than most thinks. I bought an antenna amplifier from Sayal Electronics (Mississauga) for about $29.99. Yes it is water proof, 26db gain with a power supply than happens to feed 12v via the coax cable. The 12v comes from my DC and the amplifier sits on the very top of the mast. The reception element is actually my Davis wind vane. It is insulated from the base, about 10 inches in height which is roughly 1/2 wavelength for UHF. It is vertical thus omni directional. I drilled a small hole and press fitted the centre core of a coax cable into the shank of the wind vane and then double heat shrunk the connection. Yes I have wireless engineering background ;-) In the Toronto area I got 23 HDTV stations including Buffalo, Hamilton and Toronto. Not bad for $29.95 plus a coax cable. People don't even know I have a TV antenna.
Dec 26, 2009
211
Oday 22 cleveland
Try a google on DIY Hi-Def antenna's.
I made one, enclosed it in a PVC tube with 2 caps. (abt 9" long)
Total cost about 6 bucks.
I pick up 11 channels including out local radar channel that broadcasts 24 hours. And it's non-powered.
Sep 21, 2006
280
-Hunter 35.5 Washington, NC
Friend of mine just bought an HD antenna from Walmart, mounted a couple of slides on it and runs it up his mast using the coax as the downhaul. He picks up all local channels + HD channels from out to about 100 miles. He has a Catalina 30 also.
