TV in a Beneteau 361....but where?
437
Beneteau Oceanis 361 Clipper --
I would like to install a TV on my Beneteau 361. Bringing all the cables (12V and aerial) at the bottom of the mast where it exists the saloon deck is fine. But what next? Where I am going to place the TV and the cables? The mast is not near the “wall” with the front cabin so whatever I do must be a compromise. I could not hide them. Any ideas from people with same model that have installed a TV? Any pictures probably?
Thanks
Mar 21, 2009
19
Beneteau 361 Narragansett Bay,RI
I took the door off the cabinet behind the head and replaced it with stained plywood. The TV is now the door and out of the way. The cables run above the liner to the side rail to the corner cabinet.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
It would really help if you said what size TV you're trying to install. The size of the TV will affect where it can be placed. Why is the power coming down the mast?? I can understand the aerial coax coming down the mast, but could you also route it another way.
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
If you set it up on the binnacle, you can invite neighboring crews to watch it with you.
Dec 2, 1999
15,184
If you use an articulating arm, you can mount the TV most anywhere you want. RCA makes a flat omni directional antenna (about $35-40) that will actually fit behind the TV when it is flat against the wall. These antennas can be passive (non-powered) so it is a little more economical when you are on the hook. We have had good luck with this setup. No real need to run an antenna wire up the stick.
Oct 3, 2008
59
Beneteau 361 Seattle
I mounted a Toshiba 19" with built in DVD to the forward bulkhead - stern side. I punched a hole through the bulkhead behind the TV into the cabinet behind. Then, put in an outlet in the back of the cabinet tied into an inverter mounted behind the DC panel. Suppose you could get the antenna routed into that cabinet somehow as well.
ghost
May 18, 2007
50
NULL NULL Toronto
Most newer Beneteaus have conduits that run through various parts of the boat. Mine is a 1996 and I have conduits from the chart table/ instrument panel into the engine compartment, base of the mast, and from the starboard to port side of the cabin.
Open up a few access panels around your interior and look for conduits. They will make running your wiring alot easier and help you decide where best to put the TV & associated wiring.
Or you can check your owners manual. Mine has a drawing showing all conduit locations.
