TV antennas
Palmer King
Any suggestions for a TV antenna? Preferred brand? Best mounting height/location. Any and all information would be helpful.
Bob Bass
Mount it HIGH
I have a SeaWatch 2020 by Shakesphere, but would recommend their new 2025. Remember that your signal is line of sight, so mount it as high on your mast as possible.
Jack Tyler
LOS, amplification & small profile...
The signal you're trying to catch doesn't usually bend, so higher = better. You want an amplifier in the antenna circuitry; it will make a weak signal viewable & makes up for line loss, and is a joy. And smaller with less mass up high is better. We've been very satisfied with the unit WM sells and it also receives/amplifies FM signals. Jack
H
howie
triax ufo
Two buddies of mine have the triax ufo brand tv/radio antenna. Its a booster and very small, both have them mounted on top of the mast and i've watched them enjoy many channels with it. West has them, a round $120/130 I plan on installing one for next season. howie~
Jay Eaton
USCG Notice to Mariners
INTERFERENCE TO GPS RECEIVERS FROM CONSUMER ELECTRONICS-GRADE ACTIVE VHF/UHF MARINE TELEVISION ANTENNAS The U.S. Coast Guard and Federal Communications Commission have ascertained that certain powered VHF/UHF marine television antennas are causing operational degradation in the performance of GPS receivers. This degradation in performance or interference may be realized as a display of inaccurate position information or a complete loss of GPS receiver acquisition and tracking ability. The interference interactions have been reported up to 2000 feet from the interference source. This interference has been associated, in some instances, with temperature extremes or proximity to a television broadcast site. If you are experiencing recurring outages or degradation of your GPS receiver, these may be caused by one of these antennas on your vessel or nearby. If you have a powered VHF/UHF antenna aboard your vessel, you should perform an on-off test of your TV antenna. If turning off the power to the antenna results in improvement in the GPS receiver performance, the antenna may be the source of interference in the GPS band. In that case, you should contact the manufacturer of the antenna and identify the symptoms. If the test is not positive and the GPS interference persists, you should contact the Coast Guard Navigation Information Service by e-mail or 703-313-5900, or through the web site at http://www.navcen.uscg.gov
Scott
Nothing but snow with mine
The previous owner of my 85 H-34 mounted a set of "rabbit ears" about 3/4 up the backstay. It is connected via standard cable (r59 i think). It produces the best ant races I've seen, but no other shows...fortunately our marina includes cable service... My question is what is different about the so called "marine" TV antennas that supposedly make them more effective (or in my case effective at all compared with what I have)?
