I've just read the owners' manual for that antenna.
Just running the cable inside the mast shouldn't make that much difference. I'm a bit suspicious that there may be some other issue, like for some reason when you ran the cable inside the mast, there was also a connection problem. When the cable was inside the mast, did you connect/disconnect the antenna power, and what difference did that make?
IF further tests give you the same results (ok with cable outside, lousy with cable inside mast) I would consider just keeping the antenna loose, and hoisting it on a halyard or flag line when in port. For local reception it won't matter alot that the antenna isn't on your mast top.
