My O'day 322 has two vents with solar powered fans over the head and aft cabin respectively. The two smaller vents over the main cabin are passive. Not able to find solar powered ones that size, I decided to convert them myself. Here's the result:
https://www.dropbox.com/s/tlc0gtc9cxcu6kw/Solar.jpeg?dl=0
https://www.dropbox.com/s/gy8vk8dm5pt6aj7/Fan.jpeg?dl=0
In the second photo you can see the blades whirling around.
The components I used are fans:
BP12025M6 FAN 6V DC 2P 120mm 120mm 25mm 10 inches wire 2P terminal connector $4.95 and solar panels:
uxcell 5Pcs 6V 250mA Poly Mini Solar Cell Panel Module DIY for Phone Light Toys Charger 165mm x 65mm. $18.30.
So far, they're working just fine. Total cost: $28.20.
