Tuning the rig on an H27
jfgy
Sabre 30 mk III Gainesville, FL
I plan to tune the rig on my new (to me) 1989 H27. The shrouds are pretty loose at the moment. I would appreciate any guidance about proper tension.
Thanks in advance!
Jess
May 24, 2004
7,176
CC 30 South Florida
First determine the type and size of your wires. More than likely it is 1 X 19 strand stailnless wire. The diameter could be 3/16 " but you need to size it correctly. The way tension is calculated is based on the breaking strength of the wire. For example the 1 X 19, 3/16" wire is rated at 4,700 lbs. The proper rig tension is between 10% and 15% of the breaking strength. In this example it would be around 500 lbs. To measure the tension of the wire you will need a LOOS Gauge. The tool comes for different sizes of wire. Approx. $95. You could tune the rigging without the benefit of a Loos gauge but the process is cumbersome to ensure you end with adequate tensioning and a straight mast.
jfgy
Thanks. I have a Loos guage but was not sure of the percentages to use. That's exactly what I need.
Regards,
Jess
