Tuning my hunter 386
May 29, 2016
1
Hunter 386 Rothesay New Brunswick
I just got my 2004 Hunter 386 and her mast was derigged to transport her. Can anyone give me some guidance on how best to rig her. I have placed the mast aft side up on horse, spreaders are on but I cannot connect the lower diamonds to the mast as there appears to be to much tension. I have a furling mast. Thanks
Bill Richards
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
Hi Bill,
Welcome to the Forum. Here is a link to the manual for your boat. It is on this site.
http://hunter.sailboatowners.com/dl/downloads.php?task=model&mid=63&model=386
On page 52 and 53 it has the instructions for tuning the B&R rig.
In simple terms you need to loosen the diagonals that go from the mast to the spreader tip so that the turn buckle is just engaged. Then you can do the adjustments that are outlined in the instructions. You will have to go up to the lower spreader to make the final adjustment when the mast is stepped.
Good luck.
