Sandi, tell us more about your buttons
To make sure our sheets don't pull out at the bottom. This is how we did it. We made fitted bottom sheets with the top attached to the bottom.We took the bed cushions home. We then took a set of sheets. We put the bottom sheet on the floor, the put the chsions on top of it. We then folded the sheets over the cushions, like wrapping a package. Marked where the edge folds are, then sewed the folds. We then sewed the top sheet to the bottom sheet. Done.Sewing the sheets was a lot of work, and putting the sheets on the bed is not too easy, but making the bed each morning is so very easy. Just pull up on the top sheet, and you are done. And they never pull out.Your button idea, if I understand it correctly, would be even easier. Could you give me a detailed description of it.Thanks.
