archived article
You can visit the noted websites for more info.The cabintop windows were ordered from:Bomon Marine1855a Boul. IndustrielLaval (Qc.) H7S 1P5CanadaPhone: (450) 668-3111 (800) 300-3113Fax: (450) 668-6270Email: bomon@odyssee.netAttn: Alain Cariouhttp://www.bomon.com/If needed, I can forward an Excel file with the new window layouts with dimensions. The Boman rep., Alain, was most helpful & they probably have the new window dimension on file.The portlights in the hull were special ordered through Port Supply (any marine supplier should be able to order), there was minimal gelcoat repairs with this size portlight selected, (generally only around each radius corner).LewmarSize 40 Atlantic Portlight Fixed (thick hull valance)http://www.lewmar.com/webcat/index.aspMy e-mail address is kazner@polb.comI've also attached another view of the hullKevin
