Don Guillette
TRUE WIND/APPARENT WIND When I first started sailing, this subject always confused me. I understood there were two kinds of wind (true and apparent) but I'd mix them up from a direction standpoint and I did not understand the importance and significance of either. Also, I did not know which wind is used to trim sails. It is one thing to make a sail trim change and another to know why you are making the change. True Wind is the wind you feel when your not moving. It is the wind direction your mast head fly indicates when your sitting at the dock. Apparent Wind is a combination of the speed and direction of the true wind plus the speed and direction of your boat. When your sailing, the mast head fly shows the apparent wind. OK, now that we know the difference between true and apparent wind, what is the importance of knowing the difference between the two. The importance is that you trim your sails to apparent wind, which is the same wind you feel on your face while sailing. Also, the sail trim adjustment you make is always dictated by the wind speed and direction you are sailing in. The actual wind speed, as you'll see, may not be what you think it is. When you are sailing to windward, the wind feels stronger than it is because the boats forward movement is making its own wind. Let's say the wind, while your sitting at the dock, is blowing from the south at 10 knots. This is true wind. When you leave the dock and start sailing, let's assume your making 5 knots. Let's assume you could sail directly into the wind, which you can't, but if you could the combination of true and apparent wind would be 15 knots. Make a mental note of this calculation as it is directly opposite when sailing downwind. We all know we can't sail directly into the wind so what is the speed and direction of the apparent wind while sailing to windward on a port tack in the above example? The apparent wind speed is more than 10 knots but less than 14 knots plus the direction is a little east of north. As the boat starts to accelerate, the apparent wind moves forward and you have to trim your sails accordingly. When the boat reaches full speed, you won't have to make any further changes unless the true wind direction and velocity changes and we all know the wind direction and speed is never constant. What happens in a puff or a lull? The wind direction remains generally steady but the wind speed increases or decreases dramatically. In a puff, the apparent wind moves aft approaching the direction of the true wind. You should make a sail trim adjustment to compensate for this movement, which is to ease the sails. In a lull, the apparent wind moves forward or closer to the boats direction. You should make a sail trim adjustment to compensate for this movement, which is to trim in the sails. Remember that while sailing to windward you added your boat speed to the true wind speed to get the apparent wind speed. While sailing downwind in the direction the true wind is blowing you subtract your boat speed from the true wind speed to get the apparent wind speed. Using our example of 10 knots of true wind speed, use your imagination and assume your also sailing downwind at 10 knots, which would be a thrilling downwind ride. In this case, you would not feel any apparent wind. Continuing to use our imagination, assume you've slowed to 5 knots of boat speed. Even though the true wind is blowing at 10 knots, the apparent wind you would feel on the back of your neck is 5 knots. What is the significance of all this? The significance is that sailing downwind is more of a challenge than you'd think. You have to be ready to adjust your sails quicker than sailing upwind because the boat speed changes more dramatically to a true wind change going downwind than it does while sailing to windward. In a downwind puff, the apparent wind moves aft but as the boat picks up speed the apparent wind moves forward. This can catch the unwary sailor off guard. If he knew what was going to happen when he is hit by a puff, he could anticipate the needed adjustment he is going to have to make. If he is not careful, he ends up chasing the sail. It is like the tail (sail) is wagging the dog (trimmer). Knowing what happens to the apparent wind in a lull or a puff sailing upwind or downwind can make you a better sailor.
