True and Apparent Wind
239
Hunter 35 Vancouver, BC
My boat is fitted with a Navman Wind 3100 wind instrument. It can no longer tell the differenc between true and apparent wind and gives the same wind speed on both instrument settings. Any ideas on what might be wrong and how I can fix it? Neil
Feb 17, 2006
5,274
I wonder...
If this is more of a parameter setting than a mechanical thing. Do your wind instruments work in conjunction with other instruments such as your knot meter? If your wind meter is indicating wind direction and wind speed then I would say that everything is working fine. It could be a parameter setting or it could be that your boat's knot meter is not working or not sending data to the wind computer. Just a thought.
Jun 19, 2007
77
- - Long Beach, CA
Read the manual?
You should be able to recalibrate the instrument; if it was working once, you should be able to reset it; I have to do mine occasionally. BEO
JC on Bainbridge
I would agree, check the speedo
I think the difference between true and apparent wind are calculated based on the wind speed, wind direction, and knot meter. Are all three instruments working correctly?
Aug 19, 2004
239
Mea Culpa - I'm to blame
The knot meter is not working, weed on the impeller I am sure. I tend use my GPS for speed and had forgotten that the knot meter feeds the wind instrument!! Thanks.
