Normally about 30-degrees
Normally, in the 10- to, say, 16-knot apparent range, the boat sails well right around 30 degrees apparent. This is typical but under some conditions, the speed is better when the wind angle is a tad more but almost never more than 35 degrees.The sweet spot is about 30 and more than 31 or 32 the boat tends to become less lively - you can actually feel it. In lighter winds it's best to increase the apparent wind angle and open up the gap as appropriate.With sails that have more draft there are a couple ways of looking at how to sail with the AWA (apparent wind angle). If one tries to push 30-degrees the boat will be sluggish and the sail will show signs of luffing due to the draft that shouldn't be there. So... you fall off a tad, get rid of the luffing, and the boat starts heeling more but probably only picks up a bit more speed. Any more increase in the AWA and the boat really starts heeling - especially in slight gusts - and sailing becomes frustrating. That's when it's time to make a trip to the loft for a recut, new sails, or seeing if they have any good used ones around - every once in a while they do.In the 15- to 18-kt range, and even into the low 20s, I still like to stay around 30-degrees but not because of speed. The boat seems to stand up better and is less affected by gusts. With couple sailing I go to a less-intensive work load style. The main traveler, however, gets let out a tad as that's easy to do.Datamarine made a Closehauled indicator that I always thought would be nice to have but never got. This instrument has the sweet spot angle spread out more so you can hit the numbers better but on a H-35 this is probably a little overkill.The picture is of the 5000 which is normally mounted at the helm - I removed it before winter and brought it inside to keep it from freezing as I think this protects the readouts. The picture was taken about three days ago when I was puting the heaters back onboard for the comming cold snap. Everybody was thinking that "winter" was over - were we wrong!
