Aloha everyone!
I sail a Cal 30. I was out sailing today and pulled out the jib using jib furler. The jib came all the way out but came loose at the bottom where it connects to the drum. Some of the furler line came out of the drum and wrapped around the the pole above the drum. I couldn't pull the jib in with the furler line, so the jib was a flappin in the wind. I eventually managed to haul the jib down, but forgot to cleat the jib halyard. It road up the mast and is now tangled at the top of the mast. Oh, jib sheet got tangled in the outboard propeller.
Other than that, it was a great day sailing!
The people I bought the boat from had trouble with this jib furler as well. We were out sailing together and they had trouble keeping the jib attached at the bottom, and keeping the furler line in the drum.
Is this a common problem with jib furlers? I about ready to remove it and just use a hank-on jib in a sack hung and ready at the bow.
Thanks
TC
Thanks
TC
