Hello all, I'm having trouble with the main on my '94 H26. I can raise it about 85% of the way, then it stops. There is not a kink or obstruction on the halyard anywhere that is visible at any time, I have lubed and check the slugs. When it stops, if I go to the mast where the halyard exits on the way to the turning block, it is tight there. This all tells me that the trouble is in the mast either on the way up or the way down. Any suggestions? anyone have this happen? I'd like to have some ideas before I drop the mast. Additionally, this is the first time I've splashed this year due to some previous "issues" since resolved, so I can't tell you when whatever happened happened. Thank you all!
