Trouble getting O'day 22 on trailer
Roger Smith
I am having very difficult time getting my 1981 O'day 22 (Shoal draft keel with contained centerboard) on trailer when pulling out of water. Seems to always slip to right side on edge of bottome rollers. Is there a trick to this - steep ramp, shallow ramp, drive on, winch all way on etc. I have broken the winch cable several times and am drawing the angry look of many other boat owners at the ramp as I struggle to get it on the trailer. Trailer has long rollers on bottom upon which the keel rests and two sets of small rollers on each side.
Josh
Seems to be a common problem...
How does it sit on the trailer? Looking down the trailer from the tongue, is it sitting dead center but crooked clockwise or counter clockwise, or is it shifted from the centerline of the trailer? If the problem is the former, it's simply that you have too much weight on one side of the boat. This causes it to sit in the water listing to one side, and when you pull it out thats the way it rests on the trailer. Even out the stuff you have stored in it so that it sits level in the water. If its the latter, it's just not centered over the trailer when you pull it out. Theres a number of things you can do. For now, if you have someone with you, have them hold the boat in the right position and walk along the dock as you pull it out. Better yet, do it yourself, and have them pull the boat out. A more permanent solution would be to set up some sort of guidence system to keep your boat aligned. Many people use a piece of electrical conduit with one of pvc slipped over it. This allows the PVC to roll and won't mar the boat as it slides through them. If you go the the launch on a busy day, you can easily find a trailer with these on it. A larger sailboat might require two sets of these, one near the rear of the trailer and maybe one forward of the centerline. I have also seen a PVC guidence system set up for the keel (Credit to David Clark and his 222!). This works the same as above, but is more likely to even out any gentle listing your boat might be suffering. Hope that helps, if you have any more information or some pictures, Im sure myself or others can give you more info if you need it! Josh
W
Warren
O'Day 22 "Fixed Keel/Trailer Loading"
I have a 1972 "22" - real pain to load. I attached two 8" wide planks to the trailer bed where the keel rests. then I made four "one-half" V guide than force the keel to center in the middle of the trailer. Two guides in the front & two guides at the rear. This helps alot! Also, its important that the trailer is level (side to side) or it will be very hard to center the keel. Good Luck! Warren
Dave
Keel guides
There is nothing more frustrating than having problems getting the boat loaded at the launch ramp. As Josh noted, I created a couple of guides for the keel to slide into on the trailer. This does a good job as long as the launch ramp is not too steep (which is usually the case for the places I launch). I'll get some pictures posted for you to look at within a couple of days. However, when the launch ramp is steep, the keel floats above the guides and doesn't function correctly. Thus, I'm thinking of putting a couple of trailer boat guides on the trailer (see the Boat US or West Marine catalogs for examples of these). I'll probably make these myself (with the help of a brother-in-law welder) rather than buy the pre-fabbed units. When I get that done, I'll post some more pictures.
Tom Akin
Post those ideas!
Hi Dave, Post those ideas! My boat is 4600# of unco-operative fiberglass that will be a real issue to trailer. I will be stuck doing it alone and really would apriciate any ideas to make the job easier.
