Just thought I would report back on one of the successes of my vacation. About a month ago, I was having issues with my outboard. The float stuck, which I cleaned, and then seemed to be flakey again, which I was able to get it running again. However the outboard has always been a pain, because it is a long shaft motor, and will not lift out of the water without removing it, due to the engine well size. So for having problems, it was finally an excuse to plunge into the undocumented area of electric propulsion. Being one to not take a simple no for an answer, I dug into it a bit, and found that all who had tried unsuccessfully had not really done their homework and had chosen woefully under sized motors. From my research, everything I was reading was telling me that about a 100 lbs of thrust was equivelant to a 4 HP gas outboard. I found an 86 lbs thrust motor on Ebay, took the plunge and bought it. Bought two brand new 175 minute reserve capacity batteries from Napa, and wired the boat. I will have to say this was one of the best decisions I have made regarding the boat, and was a life saver for the week long trip. With 6 people on board, and loads of extra food, we were able to cruise along solidly over 4 mph. Kind of funny, but the speed setting of 1=1mph, 2=2mph, 3=3mph, 4 =3mph, 5=4mph+. I don't have an amp meter hooked up, but the motor spun effortlessly at what ever speed setting I used, which makes me think it could use a taller prop. I need to get my amp meter hooked up to know for sure. The batteries seemed to last forever. The first two days had no wind, so we spent a lot of time motoring, just to cool off. The meter never came off 10, which was the highest number. I measured the battery voltage at the end of those two days, and it still measured 12.46 volts, which is considered 80% charged.
From a functional standpoint, electric is sooo much nicer. Being able to run the motor and not hear any sound is almost like sailing. You just glide through the water. Docking or getting into the bay area is much easier to control. Just click the motor on and off, or into reverse with the flip of the wrist. Waiting for the line up of boats to use the ramp, I could just float without noise or exhaust, with an occasional bump of the motor to keep the boat from drifting or rotating. Then when I did need to turn, the motor can be turned 90 degrees, and spin the boat quickly without any forward motion. And most importantly, if I am in the water DW has no trouble twisting the tiller to come pick me up. Lifting the outboard into place and getting it started would have been a trick.
As far as power, comparing to my 4 HP Suzuki, I would say that it doesn't have the top speed, but does seem to start the boat moving forward from a dead stop noticeably better than the gas outboard. If I'm coasting backward, and need to change direction quickly, it does it with authority. I only had it in winds of about 12 knots, and they seemed to have no affect on the speed. Maybe it accelerated slower, but over all, wind seemed to have little affect.
I did finally find a chart on the Torqeedo website which shows what they claim as equivalent thrust to a gas outboard. It shows a 3 HP being equivalent to 68 lbs thrust electric. The complete chart is here:
http://www.torqeedo.com/en/compare?pids=1403-00|1140-00|1142-00|1234-00|1232-00|3205-00
Looking at these numbers, it all looks pretty reasonable to compete with a gas outboard. I've got about 400 bucks tide up in the motor and batteries. Just purely from a cost perspective, it seems the way to go, let alone the ease of use. Not to mention, but the batteries are up front, so it gets the weight off the rear of the boat, and puts some ballast near the keel, right where you want it.
