Trimatrix
7
2 Cherubini melbourne
Looking for information regarding installation of the Trimatrix Portlights from New Found Metals) on a 1981 Hunter 30. I'm new to sailing but not to reconstruction. Alternative recommendations welcome!
Thanks
Dec 2, 1999
15,184
Do they have direct replacments for all of the port on your Hunter?
It is NOT an easy task, but it is one that you can do yourself. A fellow sailor at our harbor has installed them and they look very nice. They will work better on your boat than his. His boat is a Hunter 35 and the sides of the cabin have more of an angle than the H30.
It is just one of those things that you need to do one port at a time. You will learn as you go.
5,802
Not sure about the H30 but there are at least two photo projects for the H37-cutter here on HOW. Your portlights are identical. One of those projects is my own. I also used NFM but bronze, way before the Trimatrix. Go to "Hunter Modifications" under "Boat Info" and check the H30 and the H37C. Probably the H33 too.
Mar 22, 2004
733
Hunter 30 Vero Beach
The biggest problem with the Trimatrix port lights on an H30 is that you have three different sizes, and New Found Metals doesn't make all the sizes. So either way, you will have to buy ports from Pompanette. I actually purchased mine through the chandlery here, and they were cheaper than purchasing them direct. The plus is, that there won't be any resizing of holes in the cabin. Pull the old ones out, chip out the rotted core,
re-glass the edges to seal out any future water, and pop the new ones in. I make it sound easy, and really it is pretty simple, but it takes time and a little skill.
If the Trimatrix ports would have came in the sizes that I needed, I would have bought them. They look like a great product. I didn't want two different brands ports, it wouldn't look right.
Dave
Dec 2, 1999
15,184
Not all of the H'30 have the same port configuration.
... considering those old ports lasted for 30 years, it is not a bad idea to just replace the old ones with new ones of the same size. Even the Gray ports are not identical to the old original ones either.
May 6, 2004
916
Hunter 37C Seattle
I installed 6 of them a few years ago, exact replacement, so no cutting/filling. Rent the drill template. i "freehanded" a couple and then had the company send me the template. Tthe bolt length is critical. I ended up not using about half of the bolts sent with the order, due to varying trunk thickness. If they don't come with the "hold open" springs as standard, get them added. No calk and no leaks.
Jul 22, 2009
7
Thanks for all the comments and advice. Trimatrix does not come in the 8x18 so two ports are either plastic (Gray) or SS ($550 ea). I'm thinking six Trimatrix and two Gray's will look OK and are more affordable. mg
