Trim rings on port holes
542
Hunter 33 Seabrooke, Houston
On my Hunter 33, the trim rings are coming off and I want to glue them down
What should I use?
Should I perhaps screw them down?
I see some boats had screws, but mine has rings
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
You are right, mine are screwed down. When replacing them I have used silicone to seal the opening gap around the port beneath the ring.
5,802
Like Paul's my original Gray trim rings were secured with screws. Those that were not screwed just stuck to the original silicone caulk I think. If they are old and tend not to lay flat they might need six screws, each corner and long centers. Mine had many more than that.
784
Hunter 37 cutter Blind River
My experiences: Lots of screws = lots of possible leaks. If screw holes are countersunk for bevelled screws, the ring is weakened and splits readily if screws are slightly overtightened. I glued my new ones on with Lifecalk - or maybe it was Lifeseal (It was the one containing silicone) - and they seem to be holding. Needed to clamp them with large C-clamps.
Best tool for cutting old ones off is a really thin, sharpened 1"scraper or a Fein multi-tool with scraper blade. The chances are some rings are going to break anyway as they become very brittle with UV. I think painting them should improve longevity.
Dec 2, 1999
15,184
Sandpiper:
"improved longevity"? How long do you want this stuff to last? These boats are about 30 years old. Most other boats have sunk by now. <g>
