tricolour Trip switch
Jun 2, 2019
1
Hunter Legend 306 Tollesbury
Hi I have a Hunter Legend 306 here in the UK,
When I switch the masthead tricolour light on after about 2 seconds it trips out at the circuit breaker.
I have checked and the light does work
Any suggestions as to what may be causing this ?
If it trips you have a resistance (HEAT) building up in the wire. Check the easy stuff first. All of your connections. Especially the connections to ground (your black or yellow wires) for corrosion or maybe just loose.
Chafed wire in the mast from the wire slapping around. Turn the light on and it shorts out.
Likes: capta
Johnb
Hunter 37-cutter Richmond CA
It is also not impossible that the breaker has become faulty. That has happened to me with symptoms similar to what you describe. Chasing down wiring at the top of the mast is not that easy so if you can I suggest attaching a light if similar wattage right at the breaker and eliminating that as a possibility.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Heat would lower the resistance, and wouldn't do anything to trip the breaker that I can imagine.
Then it wouldn't light for 2 seconds, would it?
I'm betting it's the breaker, or some odd fault in the bulb. Is it an LED bulb?
That is only true for a few rare materials in the rare earth oxide family. For normal metals, heat makes the resistance go up. Actually that is how electric stove top ranges work.
jviss
Feb 5, 2004
7,090
Whoops, yes; go that one backwards. Brain fart.
  • Ha
Maybe, maybe not. If the chafed wire is in direct contact all of the time, then it would be true, except depending the current draw it may take a few seconds for the breaker to respond. Or if the wire is loose, it may take a few seconds for it move around and touch the mast to make it short.
Breakers and fuses do not always immediately blow at a short. I've cut 110v duplex wires while hot and did not blow a fuse. Ruined a nice pair of electrician's pliers in the process.
