Some of the guys on the forum have inquired about the triangular plates attached to the lower stays of the O'Day 26s which were used in mast raising on these boats. They may have put these plates on the 25s, I'm not really sure. If anyone has a 25 with these plates, maybe they could chime in on this thread.
Yesterday I went to the club and I happened to have my camera with me so I took some pics of my friend Ray's 86 O'Day 26 sitting on his trailer. I took some shots of his triangular plates that are attached to his lower stays.
Some guys have asked what size these plates are on the O'Day 26. They are about the same size as the one that was on my backstay for my mainsheet which is about 2.5"X3". I measured the distance from the deck at the chainplate to the lower hole of the triangular plate and I measured 19".
Looking at the side stays at the mast perpendicular to the centerline of his boat, the stays are aft of the mast. So I've come to the conclusion that the hole in the plate for the boom bridle does not come in line with the pivot point of the mast tabernacle. Maybe you're supposed to loosen these stays a little so that nothing binds when you're raising the mast from the bow. I really don't know.
For those who are contemplating on installing these triangular plates on the lower stays of their 25s, you may want to just consider making up some pivot bridles instead. I was able to use a small shackle between the toggles of my side stay turnbuckles on both sides of my boat for one side of the bridles, and I installed a small pad eye on each side of the deck about equidistant of the shackles for the other half of the bridles. I used braid line, two stainless steel rings, and four snaps. The bridle rope from the end of the boom could attach to the stainless steel rings on both pivot bridles. All you need to do is adjust the ropes so that your rings on your pivot bridles come even with the pivot point of your mast.
Of course, you'll want the ropes on these bridles to be even so that you can use either bridle for each side of the boat. So the placement of the pad eyes on the deck is very crucial to getting the bridles to come even.
You could also get more lateral stability for your mast by building a mast attachment out of wood to clamp on to your mast for the purpose of attaching two temporary stays which can also hook on to the stainless steel rings on the pivot bridles. This works on my boat and it can work on any boat regardless of whether you raise the mast from the bow or aft. Check it out and let me know what you think.
Joe
Joe
