The attached picture shows some wood rot in the ceiling structure of a cabin in Colorado at 8600 foot elevation. This place was built in the mid 60's and over time, the roof had a leak and you can see the results. The roof was completely replaced (now metal) about 3 years ago so no more leak. However, I still get a "musty" smell when the place has been closed up for a while and it warms up. FYI, the "white" you see is from when I sprayed the area with a diluted clorox solution and will probably wipe off.. The dark is the wood rot - and the problem.
No way am I going to replace the beam and ceiling wood.. so what is the best (or at least a sort of good) "bandaid" for this type of wood rot?
edit.. maybe something like this? http://www.rotdoctor.com/log/Lrepair.html
