Traveller
Oct 30, 2019
1,021
Dear Tom,
My trtaveller is also in the original position as
is yours. The rest of my brightwork I have done with cetol but the tiller I just
used teak oil as it is easy to touch up when it gets a bit scuffed. I would be
reluctant to movethe traveller as it seems a pretty strong set up where it
is. The sheet I tend to throw on the stern cushion to keep it away from the
rudder post and I think it is a bit easier to reach there when needed.In
one of the Vega newsletters a while ago was a description of how one
person rigged a main sheet/traveller equivalent set up on the cabin roof.
Some concern was expressed by another owner based on the designer's thoughts as
to wether the coach roof was really robust enough in the long term for
this.
Happy sailing,
Iver Theilmann (Hull #
2490)
May 9, 2011
1,000
Fellow
Vegatarians:
I though I
might add my thoughts…why mess with a great design? There may be some drawbacks
(minimal) regarding the position of the traveller, however it is easy to make main-sheet
adjustments in its present location and the forces that act on the traveller
under any conditions are substantial. I would advise against moving it
anywhere. As well, I have also used Cetol to finish all the brite work and the
results are great.
Regards,
Brian (#1039)
May 9, 2011
1,000
_filtered #ygrps-yiv-2060159992 {
font-family:Tahoma;}
#ygrps-yiv-2060159992 P.ygrps-yiv-2060159992MsoNormal {
FONT-FAMILY:"Times New Roman";FONT-SIZE:12pt;MARGIN:0cm 0cm 0pt;}
#ygrps-yiv-2060159992 LI.ygrps-yiv-2060159992MsoNormal {
#ygrps-yiv-2060159992 DIV.ygrps-yiv-2060159992MsoNormal {
#ygrps-yiv-2060159992 P.ygrps-yiv-2060159992MsoAutoSig {
#ygrps-yiv-2060159992 LI.ygrps-yiv-2060159992MsoAutoSig {
#ygrps-yiv-2060159992 DIV.ygrps-yiv-2060159992MsoAutoSig {
#ygrps-yiv-2060159992 TT {
#ygrps-yiv-2060159992 SPAN.ygrps-yiv-2060159992EmailStyle16 {
COLOR:navy;}
#ygrps-yiv-2060159992 DIV.ygrps-yiv-2060159992Section1 {
I
agree, Brian. I like having the traveller right where it is.
Steve
DeMont, "Erendira" (#2947)
May 9, 2011
1,000
_filtered #ygrps-yiv-420311532 {
#ygrps-yiv-420311532 P.ygrps-yiv-420311532MsoNormal {
#ygrps-yiv-420311532 LI.ygrps-yiv-420311532MsoNormal {
#ygrps-yiv-420311532 DIV.ygrps-yiv-420311532MsoNormal {
#ygrps-yiv-420311532 P.ygrps-yiv-420311532MsoAutoSig {
#ygrps-yiv-420311532 LI.ygrps-yiv-420311532MsoAutoSig {
#ygrps-yiv-420311532 DIV.ygrps-yiv-420311532MsoAutoSig {
#ygrps-yiv-420311532 TT {
#ygrps-yiv-420311532 SPAN.ygrps-yiv-420311532EmailStyle16 {
COLOR:navy;}
#ygrps-yiv-420311532 DIV.ygrps-yiv-420311532Section1 {
Dear Friends,
I could not agree more , I did not understand why it
would be beneficial to move the traveller to another place,
Regards,
Henk Jansen Netherlands
quote: A change alone is unchanging Heraclitis Greek
philosopher.
