Don Guillette
Mates: A beginning sailor lister contacted me by phone yesterday about some confusion he had as to how the traveler functions. My explanation to him my help a few other beginners. This may be boring to most of you who know how the thing works. It really used to confused me as a beginner.All the traveler does is change the angle the sail points to the wind. Its called the angle of attack. Sailing close hauled, the more you move the traveler up the track (changing the angle to the wind) the more powerful the sail becomes. Let the traveler down the track and it becomes less powerful. The traveler does not change the SHAPE of the sail. To see this, visualize a screen door. Where the hinges connect to the door frame would be the mast. Assume someone put a pin on the bottom of the door and the pin went into a groove on the floor and when you opened the door, the pin followed the groove. In this scenario, when you opened or closed the door, would any part of the shape of the door change? It obviously wouldn't. It is the same with the traveler on your boat. In fact, you could go to the Santa Fe RR yard and get a 20' section of RR track and slap it on your boat and move your traveler car the whole length of the track and the shape of the sail would not change.On the other hand, if you move the cunningham or halyard your changing the vertical shape of the sail. If you move the outhaul your changing the horizontal shape of the sail. The boom vang kind of changes things vertically and horizontally. The fairleads and jib halyard have the same effect on the jib. In other words, those controls stretch the sail cloth and thus change its shape. The traveler doesn't stretch anything so the shape doesn't change.The only exception is moving the traveler car on curved traveler track on the C30. The shape change is slight but there is a change. C30 owners should consider replacing the curved track with the Garhauer straight track system. It works better. I hope that explanation helps a few folks to understand a bit better how the traveler control works.
