Traveler mount bracket on 280
Dec 28, 2014
61
Hunter 280 Mandeville, LA
Have a 280 and noticed last week that the rectangular stainless starboard mount for the cabin-top traveler, which has welded corners is splitting at the weld. Anyone else run into this issue? Four bolts with phillips heads mount it to the cabin top and it was an SOB getting it off. One bolt hole was not drilled true and the bolt itself was bent within the frp which was pretty thick. Anyway, definitely a manufacturer assembly quality issue Ahoy Hunter, not a happy camper here!
