I'll be installing a new traveler (a Garhauer MT-1) on my boat this spring (if winter ever ends) and have a question on how owners usually connect the control lines. The traveler has track mounted end controls, each with double sheaves (max. 1/2 inch line), cam cleat and becket. The car has double sheaves on each end.I was originaly planning to order new 7/16 inch control lines with eye splices to connect to the beckets. But then I was wondering if the splice tail would be two stiff and wide to pass smoothly around the sheave on the car when the traveler is let out all the way to leeward. Options are to just tie a bowline or something similar. What have you folks done?Thanks,Kevin B
