Cutless bearing
There has just been a lengthy discussion of this subject as it relates to Beneteaus on the Beneteau Google list. Here is the most recent discussion: Dlm48@aol.com to Beneteau-Owners More options 6:43 am (4 hours ago)In a message dated 26/01/2006 04:34:06 GMT Standard Time, mohawk@msn.com writes: It is necessary, you are lubricating your shaft by forcing the water from behind the bearing by forcing it through as your shaft turns . The cool water is pushed through in another word all the time. Bearing being in the water as the shaft turns does not allow enough water to climb up through the bearing and since the other end is in your boat and stopped either by stuffing box or drip less the water starts boiling and evaporate due to the friction thus your bearing is not getting cool. Marratu Oceanis 461 #168 Galveston, Texas M. M. Bayegan ----- Original Message ----- From: Robert Gales To: Beneteau-Owners@googlegroups.com Sent: Wednesday, January 25, 2006 8:08 PM Subject: {Beneteau Owners} Cutlass bearing hose Is this hose to supply water to the cutlass bearing necessary? Volvo says that the bearing needs to be under water so it can be lubricated. So is the hose really needed? The installer of my new Volvo D130 said it may not be necessary (as did some sailnet list members) due to the fact it is not a high rpm turning shaft. My new engine is being installed this week and I want to make sure everything is hooked up correctly. I am still concerned about the stiffness of the Volvo seal. Thanks for any comments, Bob Gales Welches, ORBy cutlass bearing it take it that we are meaning shaft log/stuffing box - the cutlass bearing should be happily immersed in the water at all times even on the Oceanis range where it is in a skeg in the hull. On a sail boat a water injected shaft log is a nice to have feature but is not needed. It is needed on a planing powerboat when there is liable to be enough movement through the water to drain the prop tube the combination of that and the fact that the boat will plane on top of the water not deeply immersed in it - these factors would cause the high sped aft flowing water flow to drain the water out of the prop tube and therefore the bearing would run dry - so to avoid that you force water in there constantly. Without this feature on your sailboat you have to bleed the tube so that there is water in there - you do that at launching by burping the seal seat until you get water out. In order to avoid the need for this 'bleeding at launch time' some boat manufacturers use the water injection nipple and attach a vent line to it that runs above the water line and can either have a loop or a valve in it. Cant imagine the water boiling or evaporating in the shaft of any Bennie sailboat. The shaft is not turning fast enough to create enough heat for even localised boiling and we sail in millions/trillions of gallons of water so any evaporation IF it did or could take place would be instantly be replaced. So a water injected shaft log is a nice to have thing - but not really required on any sailboat and would seem to cause more problems than it solves so in reality is not nice to have feature. don't worry if you have one and don't worry if you don't. i am not sure what the 'official' rules in any marine certification regime are but i think it is 15 knots and above before you need a water injected shaft log. regards David
