transporting the outboard
49
Oday Javelin mid-Michigan
I have been transporting my outboard in the back of my pickup because I am nervous about the thought of all that weight hanging off the pivoting motor mount as I go bouncing down the road. I just upgraded to a 9.8 hp 4 stroke this year, so the weight went up to about 110 pounds. In order to get more leverage to be able to pivot the motor mount up when I am in the water, I tied a line to my stern rail, ran it down to a small block at the motor, and pull up on it to raise the motor. Then I got to thinking that if I put some tension on that rope and cleat it off on my stern cleat at the top of the transom, I could have the stern rail and stern cleat supporting most of the weight of the motor.
Does that sound like a safe way to transport the motor down the road? I could probably run another line forward from the stern rail to brace it a bit. That could prbably shave 15 minutes or so off of my setup and teardown time.
Wayne
Feb 20, 2011
8,062
No. At least I wouldn't do it.
Think of those 15 minutes as transom insurance.
Ward H
Nov 7, 2011
3,843
If that is a 14' boat, I would really question putting a 9.8 100lb motor on that size of a boat. Even a 4hp at half the weight will be more than enough push and would make launching much easier.
I would even worry about the 9.9 having more tourqe than the transom can handle.
Agree with Justsomeguy about not trailering it mounted.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Yeah, a 110 pound motor on a 14' Uffa Fox designed Javelin?
I'm sure Wayne has this 9.8hp on a bigger boat!
Brian
NEVER leave a motor on a boat on the highway/road. Not only do you lose the motor, you gain a lawsuit from the guy behind you.
Aug 27, 2010
49
I should have mentioned that this is on a 23, not a Javelin. (I use an old electric trolling motor on that one.) I know that the previous owner used to drive it with the motor on, but I didn't like the idea of all that weight just hanging off of the motor mount. I was just thinking that with more support, the transom could safely handle it.
1,957
Oday Day Sailer Wareham, MA
I don't think the stern-rail is really designed/built to handle that kind of load, and even so I don't think that tying the outboard up as you mention will remove the side-to-side flexing from the bracket.
I do trailer my DS II with the 4 hp outboard clamped to the transom, but that OB only weighs about 38# and I'm only towing 4 miles on town roads (speed no more than 45 mph and smooth roads, mostly 30 mph or less).
Erieau
Apr 3, 2009
209
Oday 25 Erieau
15-horse Honda, all 120 pounds of it, stays right where it's put during trailering. Removal invites injury. To spare the transom the shock loads of the road, I use a ratchet strap around the stern rail, cranked up 'til the motor mount is being pulled slightly upwards. 6 complete 40-minute trips so far, and no problem with either the transom or the stern rail.
Your mileage, quite literally, may vary.
