Transom Swim Ladder
C
Craig
I'm looking for a source that will have replacement swim ladders for my 1983 C30. It appears as if the ones Catalina Direct sells only go up to the C27 models.
Joe
Jun 1, 2004
8,323
Call the factory...
http://catalinayacts.com or check west marine, defender, boat us etc. there are many sizes and styles of boarding ladders offered by a number of manufacturers. http://www.cgedwards.com/garelick/gar10.html http://us.binnacle.com/product_info.php?cPath=117_146&products_id=2402&osCsid=69f992205a7f5ef9b4ba85eb6b5563f0
Jack Swords
New swim ladder for a 1983
We have a Cat 30, 1983 in La Paz. Badly damaged in Hurricane Marty 2 years ago, we got ALL stainless from the Catalina factory. Pulpits fit as original, but ladder was a bit too long (extended about 2 in above stern pulpit when folded up). I filled the holes from the destroyed ladder and just drilled new ones about 2 in below the old ones on the transom. While at it I added a backing board inside the lazarette to help support the ladder (original had large washers). The ladder is like the new ones in that it has the white steps attached to the tubular steps. Much nicer than original. Call Catalina and they will help you.
