Transom rating?
bshup
Apr 20, 2005
4
Catalina 27 Lake Whitney Texas
What is the largest HP outboard that the 27 is rated for.
Peter
Don't know that there is such a rating
If you're talking about the 27 that was designed for an OB (with the hole in the transom and a motor mount approx 12" above the waterline) the question more is "what is the maximum powerhead size that will allow the motor to tilt up?" When manufactured, the C27 was recommended by Catalina for 6HP. Now most of us seem to require at least 8. The old (up to about mid 90s) Johnson/Evinrude 9.9 was perfect. Could push the boat at hull speed (6.2) at full throttle, was small enough to fully tilt out of the water, but yet fairly easy on the gas for a 2-stroke (.66-.75GPH at 3/4 throttle). And dealers and parts are everywhere. If you want a new motor there are fewer options without surgery to the transom. From posts and e-mails here, and my own measuring, there are apparently NO 4-stroke motors above about 6HP that will fit w/o some surgery. Yanmar recommends 1HP for every 500 lbs of displacement. Albeit, Yanmar is in the business to sell (bigger) motors, but for a Cat27 (7-8000lbs) that's about 15HP.
rsn48
Jun 7, 2005
257
- - Sewell Marina - West Vancouver
Not transom rated but hull speed rated
Hull speed on a Catalina 27 is 6.3 knots, so jet propulsion won't take it above that speed - okay, maybe a jet might but do you really want to be on board when it does? Most sail boats in the 25 - 28 range use a 9.9 motor. On my Catalina 27 with a new 4 stroke Merc 9.9, I don't need all the power to reach hull speed. 15 horsepower is over kill for the Cat 27. It cost me around $800 to have the transom fully enclosed and the new transom re-gel coated; it looked brand new. After this you can add what ever manual or power bracket to it to take a new 4 stroke engine. And oh yes, you can more storage room in your transom locker. One big recommendation if you do this; enlarge the drainage hole to as large as you can get it, you won't regret that move either. Probably your cockpit scuttles drain into your transom locker and if that frigging original tiny hole is plugged you have problems. I installed a secondary drainage system for the cockpit scuttles, independent of the transom storage locker. I have tubes, the same as under your sink, going from the cockpit scuttle to a new transom drainage hole, exclusively for the new drainage system. The old wider hole drains whatever else gets in the transom.
bshup
Apr 20, 2005
4
Thank you
That answers my question. I have a Merc 5hp long shaft and have trouble getting back into my slip in high winds. I needed to know how much hp the transom could stand and you guys did. thank you
