HI
I have a 1989 272 with inboard. I bougth a garmin 90dv chartplottr/gps that comes with a transom mount. Has anyone used a transom mounted transducer with good results. I worried the transom is too high to keep the transducer under water enough top properler work. Any help is appreciated.
thanks
Paul donelan "BEAM'
want to let you know I sanded a spot under 1/4 berth and tried the transom tranducer dry "nothing" I then ''buried'' the unit in two toilet wax rings. for about an hour the depth was blank but THEN it worked! been accurate for a week now so hope for the best.
thanks
Paul donelan "BEAM'
