My transom seems to flex from the weight and thrust from the outboard motor. Does anyone else experience this? The only thing inside the hull on the mounting bolts are fender washers. I could see this causing the gelcoat to flex over time, but the boat is an 82' and hasn't had a problem yet. I'm used to super strong transoms on powerboats.
We're using a 9.9 Evinrude Sailmaster longshaft.
John
John
