Richard McBrid
Hi all. I have a '78 Catalina 27 with the transom cutout for the outboard. I don't care for this arrangement, but that is moot anyway, as my new 4-stroke 9.9 Merc will not fit it anyway. I am looking at two ways of dealing with the new motor mounting. One is to cover over the transom hole. In this plan, we would use 3/4 marine plywood as a backing bolted through the thicker part of the transom. We would then add an additional build-up where the actual hole is, thus making the stern reasonably flat across. Then we would add a mount a regular outboard motor mount on this build-up, allowing use to raise and lower the motor. The other method would be to use some form a mount using the transom cutout as the mounting frame. A company called Breeze Industries (http://www.breezeindustries.com) makes one of these specifically for the Catalina 27. My concerns with the first plan is the strength of the transom with the mount on the framed over part. My concern with the second plan is that it leaves the transom open. I am looking for comments. Thanks
