possibles
most of the outboards have sliding dogs, with use the edges get rounded and power causes them to slide out by riding the 'ramp', it is not a hrad fix, with new parts it's a 20 minute to 1hr job depending on style of lower unit, with repairing the old parts it's slightly longer, normaly repair means filing the ramp off so everything is square again then polishing/smoothing so it doesn't hang up. second common lower end trouble is that the shifter fork is worn or bent so it doesn't fully engage the chutch, which will cause it to pop out. (and will lead to the above problem) Bending is most often caused by fast shifting, such as when trying to manuevor in a tight area that you have to constantly switch forward and reverse. Most of the newer outboards have plastic caps on the end of the fork, and it's a quick fix, open up, remove old caps, clean out any junk, and reassemble, bent forks are sometimes easy, other times a more complicated teardown sometimes excited shifting can bow the shift rod, which will make it not fully engage, normally this is accompanied by your indicator changing position or a new 'springy' feel in the shift. another cause is crud build up in the shift mechanism, not letting it fully engage the detent, so any power application causes it to drop out of gear, if your shifter is 'buried' it's a good starting point. for the most part if you are comfortable dropping the lower end to change the impeller, odds are you can rebuild the bottom end electric shift types are a bit more complicatedken
