universal M-24xpb with ZF-10N transmission. Just over 200 hrs, new 2010.
A few time this past season it seemed not be in gear while maneuvering in the marina. While taking it to the fuel dock for final pump out and top off it seemed to be going slower than it should for the RPM. Shaft was turning. After a few minutes it seemed to suddenly engage fully and speed was normal again. Other than checking the ATF level and replacing the prop shaft key when lap fitting the prop as Main Sail outlines, I have not touched the drive train in the three years I have owned her.
So lots of questions:
Does this sound like a clutch or damper plate issue?
How hard is it to get the trans off the engine? How heavy are they?
I have a PSS shaft seal would that leak if done in the water? The boat is on the hard now. Would like to maybe try the diesel fluid flush trick first in the spring after launch if that may help.
If I do remove it, where should it be rebuilt?
I know, I ask a lot o questions for someone from NJ but marine transmissions is one of the many topics I know nothing about.
