Transmission Clunk
Slep
Sep 9, 2007
8
- - Forked River, NJ
I am getting a more pronounced "clunk" than usual when shifting from forward or reverse gear to neutral. You can hear it and feel it. Forward and reverse both seem to work normally. Any ideas on what this could be?
Bearboat
Nov 6, 2006
10,256
First make sure the idle speed has not increased.. then, Check the prop and coupling for looseness.. Before running, when everything is nice and cool,(trans in neutral) grab the coupling and rotate by hand quickly one way then the other, only about 1/8 turn .. if anything is loose you'll feel the "thunk" ..A suspect place is where the shaft enters the coupling... also check the shaft support strut for looseness.. You should be able to find where the strut is bolted to the hull, just in front of the rudder post.. (don't try to tighten the nuts without someone holding the bolts from turning outside the boat) or dive under and try to wiggle everything by hand.. If all that stuff is tight then it starts getting interesting.. The "spring plate" inside the bell housing, the part that drives the transmission would be a suspect, the motor mounts, and finally, the transmission itself.. Have you checked/changed the transmission oil , looking for metallic flakes?? Lots of metal or very black oil could mean a bearing or gear in the process of failing..
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
After Kloudie's recommended checks there is the possibility of a loose prop on the shaft or, more likely, loose blades on a folding or feathering prop.
Presumably you pause between forward and astern to allow things to stop rotating.
Feb 6, 1998
11,772
Check....
Prop
Coupling
Damper Plate
Coupling Bolts
That shifter is engaging fully
Slep
Sep 9, 2007
8
Bearboat
Thanks all for your great advice. I have a fixed, two blade prop and I always wait in neutral before shifting. I will definitely try your other suggestions.
