Pull the motor
I had to pull my motor as part of a repower last year. It's really not that big a deal. Just remove all hoses, wires, fuel lines, etc. Remove the coupling to the prop shaft & remove all 4 bolts that hold the motor in place.Remove the mainsheet from the traveler, open the sliding hatch all the way & use the mainsheet & boom to lift the motor up & over the side. I used a wheel barrow on a finger pier & just wheeled the motor away (in my case, to the dumpster).I hope this helps.Allen Schweitzers/v DrambuieHull #632
