RFerraro1
On a 1984 Beneteau First 32 with Renault engine.
Forward gear runs fine but in reverse the propshaft seems to slip, or turn slowly even when the engine revs up. This problem only arose after I replaced the stuffing box which required some heavy duty heat, and pounding to free the driveshaft from the collar connecting it to the transmission. I must have done some damage but I'm hoping it just needs an adjustment. All ideas welcome. Could it be that the clutch is slipping, and if so what does it take to fix it?
