L
L Baker
Whilest out on the lake this weekend, motoring up to set anchor on lake Grapevine here in Texas, I suddenly heard a loud "whomping" vibration (in forward or reverse), then I suddenly lost all power. Engine would rev in either direction, but no prop turning.To keep the story short, I ended up below looking at the shaft-transmission coupling plates sitting about an inch apart, with four bolts, nuts, and lock-washers lying around in the access bay. The transmission and the shaft had *completely* decoupled while under way! There was no outward sign that I can remember that these bolts were loosening, and the bolts weren't stripped (thank goodness - it was a simple matter with a pair of pliers and a crescent wrench to put it all back together and torque the bolts tight enough to feel good about motoring back in that evening). I've now got both plates firmly pressed together and the bolts torqued "hand tight," meaning as tight as I'm willing to pull without fear of stripping the nuts.The history: I took delivery of this 1999 pre-owned Hunter 310 from a dealer, that had taken it in on trade. Part of the deal was to move the boat from another lake in Texas, and to repaint the bottom. They did all of this without any complaints, and seemingly did a good job. However, I am wondering if there is some typical practice involved in repainting bottoms, moving boats, etc. that would involve decoupling the tranny. If so, then I want them to be aware that whoever re-assembled the coupling it did it very poorly.Otherwise, I can only conclude that the bolts had vibrated loose over time. I didn't notice this when we were doing the survey, and neither did the surveyor; it seems like it would have been obvious to spot separation between the coupling plates. So I'm guessing that the bolts were loose, but had not worked loose. We've probably put 3-4 hours on the engine under power since we took delivery. There were 76 hours on the engine when we acquired the boat.If anyone has any ideas about how this sort of thing could have occurred, I'm all ears.Should re-tourquing the transmission coupling bolts be a regular maintenence item?Also, mabye I'm just paranoid, but I seem to notice vibration while under way a little more than I did before. Can't really tell. Could my experience have put the shaft out of alignment?Thanks for all the support. This forum is a great place to ask questions!Best regards,Larry Bakerc/v "Flat Broke"Grapevine, TX
